Is it possible to cast music from my Android phone to a HASS instance running on a Raspberry Pi 4B?
I am curious if I could run some kind of Google Cast server of some sort on the raspberry where the HASS instance is running and then simply cast my music from my phone to the Raspberry Pi and it would play through the raspberry’s 3.5mm jack.
Hi @DJsushi
I have never done it before but this reads promising … just installed it and checked if you can select the output on the device itself and yes …
so feel free to give it a try and it would be nice if it works you could reply back here… thank you
https://github.com/home-assistant/addons/tree/master/vlc
Thank you very much, I tried it out and it isn’t exactly what I was hoping for. Basically, what I would like is an ‘emulated’ TV sort of, something that I can directly cast to from my phone, something that would appear in the menu when I click the “cast” button in the corner of a YouTube Music song.
