I have a 4 channel relay on a nodemcu.
Which looks like this.
switch:
- platform: gpio
pin: D1
- platform: gpio
pin: D2
- platform: gpio
pin: D3
- platform: gpio
pin: D4
How can i setup these as lights ?
I can only do one of the relays with this. Couldn’t manage to get the other 3 working.
nickrout
(Nick Rout)
4
Please post the yaml and logs for what doesn’t work.
This is what it looks like.
light:
- platform: binary
output: light_output1
- platform: binary
output: light_output2
- platform: binary
output: light_output3
- platform: binary
output: light_output4
output:
- id: light_output1
platform: gpio
pin: D1
- id: light_output2
platform: gpio
pin: D2
- id: light_output3
platform: gpio
pin: D3
- id: light_output4
platform: gpio
pin: D4
Log
INFO Reading configuration /config/esphome/isiklar.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing isiklar (board: nodemcuv2; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|-- <ESPAsyncWebServer-esphome> 2.1.0
| |-- <Hash> 1.0
| |-- <ESP8266WiFi> 1.0
|-- <DNSServer> 1.1.1
|-- <ESP8266mDNS> 1.2
|-- <noise-c> 0.1.4
| |-- <libsodium> 1.10018.1
RAM: [==== ] 41.8% (used 34204 bytes from 81920 bytes)
Flash: [===== ] 48.0% (used 501189 bytes from 1044464 bytes)
========================= [SUCCESS] Took 1.63 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of isiklar.local
INFO -> 192.168.50.110
INFO Uploading /data/isiklar/.pioenvs/isiklar/firmware.bin (505344 bytes)
INFO Compressed to 354412 bytes
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from isiklar.local using esphome API
INFO Successfully connected to isiklar.local
[00:51:38][I][app:102]: ESPHome version 2022.6.2 compiled on Aug 3 2022, 00:49:15
[00:51:38][C][wifi:491]: WiFi:
[00:51:38][C][wifi:353]: Local MAC: EC:FA:BC:63:3E:C8
[00:51:38][C][wifi:354]: SSID: [redacted]
[00:51:38][C][wifi:355]: IP Address: 192.168.50.110
[00:51:38][C][wifi:356]: BSSID: [redacted]
[00:51:38][C][wifi:358]: Hostname: 'isiklar'
[00:51:38][C][wifi:360]: Signal strength: -46 dB ▂▄▆█
[00:51:38][C][wifi:364]: Channel: 7
[00:51:38][C][wifi:365]: Subnet: 255.255.255.0
[00:51:38][C][wifi:366]: Gateway: 192.168.50.1
[00:51:38][C][wifi:367]: DNS1: 192.168.50.1
[00:51:38][C][wifi:368]: DNS2: 0.0.0.0
[00:51:38][C][logger:275]: Logger:
[00:51:38][C][logger:276]: Level: DEBUG
[00:51:38][C][logger:277]: Log Baud Rate: 115200
[00:51:38][C][logger:278]: Hardware UART: UART0
[00:51:38][C][gpio.output:010]: GPIO Binary Output:
[00:51:38][C][gpio.output:011]: Pin: GPIO5
[00:51:38][C][gpio.output:011]: Pin: GPIO4
[00:51:38][C][gpio.output:011]: Pin: GPIO0
[00:51:38][C][gpio.output:011]: Pin: GPIO2
[00:51:38][C][light:104]: Light 'Light 1'
[00:51:38][C][light:104]: Light 'Light 2'
[00:51:38][C][light:104]: Light 'Light 3'
[00:51:38][C][light:104]: Light 'Light 4'
[00:51:38][C][captive_portal:088]: Captive Portal:
[00:51:38][C][mdns:084]: mDNS:
[00:51:38][C][mdns:085]: Hostname: isiklar
[00:51:38][C][ota:085]: Over-The-Air Updates:
[00:51:38][C][ota:086]: Address: isiklar.local:8266
[00:51:38][C][ota:089]: Using Password.
[00:51:38][C][api:138]: API Server:
[00:51:38][C][api:139]: Address: isiklar.local:6053
[00:51:38][C][api:141]: Using noise encryption: YES
[00:51:48][D][api:102]: Accepted 192.168.50.109
[00:51:49][D][api.connection:861]: Home Assistant 2022.7.7 (192.168.50.109): Connected successfully
and looks like this
nickrout
(Nick Rout)
6
So when you flash that you’ll get logs. We need them. (I did ask).
Ok got it. Didnt renew the card :S It is all good now.
thanks for the replies
