Is it possible to control a Stepper through a box input number?
Got my ESPHome Stepper working, but since I want to use it for fertigation (and not for blinds as apparently most of us do), I need to extend my control beyond the default slider. It would be great if I could manage:
  • a box where I can input the precise number of steps I need the pump to make (instead of the slider);
  • a button that can reset the position of the motor, to zero, for example.
Any thoughts? Thank you in advance for giving an hand to someone without programming skills.
My ESPHome device config is like so:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
  services:
    - service: control_stepper
      variables:
        target: int
      then:
        - logger.log: "Speed updated"
        - stepper.set_target:
            target: !lambda 'return target;'
stepper:
  - platform: uln2003
    sleep_when_done: true
    pin_a: D1
    pin_b: D2
    pin_c: D3
    pin_d: D4
    max_speed: 250 steps/s
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Stepper1 Fallback Hotspot"
    password: "xxxxxxxx"
captive_portal:
My HA config file earned this bunch:
# STEPPERS
input_number:
  stepper_control:
    initial: 0
    min: -1000
    max: 1000
    step: 1
    mode: slider
And my automations.yaml file got this:
- id: '1661897634736'
  alias: Write Stepper Value to ESP
  - platform: state
    entity_id: input_number.stepper_control
  - service: esphome.stepper1_control_stepper
    data_template:
      target: '{{ trigger.to_state.state | int }}'
All I can get is this in my dashboard:
Untitled
I can help with the first.
change “mode: slider” to “mode: box”
I tried that before, but it didn’t worked. At least this plain change does not work.
EDIT: yes this works! Little issue in config code. Now it is okay.
Thank you very much for giving me an hand :slight_smile:
Now I just need a reset button…
For the second, part you could just make an automation that resets the steps back to 0 and then use a the tap method in a card to reset it:
tap_action:
      action: call-service
      service: automation.trigger
      service_data:
        entity_id: automation.step_reset
I think that would work for you.
Many thanks for the suggestion. I will try this now and will come back with an update.
So I created this button in my dashboard, as you suggested, and I’m currently playing around the automations and can’t figure how to create one that resets the value of my stepper. Probably very simple but…
Can you please tell me a bit more how to do this?
Once again thank you very much.
I think something like this would work, I create a trigger that would never happen, cause I’m not sure if you can create an automation without a trigger:
id: Stepper Reset to Zero
alias: Stepper Reset to Zero
  platform: numeric_state
  entity_id: sensor.uptime_sensor_stepper1
  below: -120
  - service: esphome.stepper1_position
      position: '0'
Tried this, but when I try to execute the automation, it does not work. My stepper value stills the same, does not resets.
Try this:
  below: -120
      position: '0'
      target: '0'
Still does not resets. I’m getting this error " Unable to find service esphome.stepper1_position"
You need to add this to your esphome yaml and upload it:
api:
  encryption:
  services:
      variables:
        target: int
      then:
    - service: stepper_position
      variables:
        position: int
      then:
       - stepper.report_position:
            position: !lambda 'return position;'
    name: "Stepper Position"
    unit_of_measurement: steps
    lambda: return id(stepper1).current_position;
    update_interval: 1s
Updated and uploaded the ESP device. Still does not resets. Still the same error “Unable to find service esphome.stepper1_position”.
After that you may need to restart Homeassistant, to pickup the new entities.
yep, I did restarted before trying again. Still no reset.
I think I see the issue, we need to change:
      variables:
        position: int
to
    - service: stepper1_position
      variables:
        position: int
Now, neither the stepper nor the reset automation work.
Make sure you valid the esphome config, to check for errors.
Ok, I will check this tomorrow and will let you know. Thank you again for so much help! :slight_smile:
Hi again, sorry for only being able to check this atm. I double checked the ESPHome config, it validates ok. The stepper motor is working again (it was a misplaced cable).
But Im still unable to reset the position.
For convenience, here is the code I currently have:
ESPHome device:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
api:
  encryption:
    key: "xxxxxx"
  services:
      variables:
        target: int
      then:
      variables:
        position: int
      then:
stepper:
  - platform: uln2003
    pin_a: D1
    pin_b: D2
    pin_c: D3
    pin_d: D4
    update_interval: 1s
ota:
  password: "xxxxxxx"
wifi:
  ap:
    password: "xxxxxx"
captive_portal:
My automation for reset:
  - platform: numeric_state
    below: -120
      position: "0"
      target: "0"
My automation for writing value:
  - platform: state
    data_template:
My HA config:
  stepper_control:
    initial: 0
    min: -50000
    max: 50000
    step: 100
    mode: box
Once again, tank you for all the help!
Ok first thing I found, that I missed we need to change to this:
    below: -120
  - service: esphome.stepper1_stepper1_position
      position: "0"
      target: "0"
