Hi
Thx for the response. I saw the lambda functions, but I cannot figure out how to put my code into 1 single lambda function.
Below the code as a custom sensor:
project.yaml
esp32:
board: nodemcu-32s
framework:
type: arduino
esphome:
build_path: "./build"
logger:
- platform: dht
model: DHT11
pin: 25
update_interval: 5s
temperature:
humidity:
- platform: ldo_peakdetect
sensor: humidity
algorithm: NORMAL
lag: 10
threshold: 2
influence: 0.2
epsilon: 0.02
sensor.py
import esphome.codegen as cg
import esphome.config_validation as cv
from esphome.components import sensor
from esphome.const import (
CONF_SENSOR,
STATE_CLASS_MEASUREMENT,
ICON_FLASH,
CONF_ID,
ldo_peakdetect_ns = cg.esphome_ns.namespace("ldo_peakdetect")
LdoPeakDetect = ldo_peakdetect_ns.class_("LdoPeakDetect", cg.Component, sensor.Sensor)
CONF_ALGORITHM = "algorithm"
CONF_LAG = "lag"
CONF_THRESHOLD = "threshold"
CONF_INFLUENCE = "influence"
CONF_EPSILON = "epsilon"
LdoPeakDetectAlgo = ldo_peakdetect_ns.enum("LdoPeakDetectAlgo")
ALGORITHM = {
"COMPARE": LdoPeakDetectAlgo.COMPARE,
"NORMAL": LdoPeakDetectAlgo.NORMAL,
CONFIG_SCHEMA = (
sensor.sensor_schema(
state_class=STATE_CLASS_MEASUREMENT,
.extend(
cv.GenerateID(): cv.declare_id(LdoPeakDetect),
cv.Required(CONF_SENSOR): cv.use_id(sensor.Sensor),
cv.Required(CONF_ALGORITHM): cv.enum(ALGORITHM, upper=True),
cv.Required(CONF_LAG): cv.int_,
cv.Required(CONF_THRESHOLD): cv.int_,
cv.Required(CONF_INFLUENCE): cv.float_,
cv.Required(CONF_EPSILON): cv.float_,
.extend(cv.COMPONENT_SCHEMA)
async def to_code(config):
var = cg.new_Pvariable(config[CONF_ID])
await cg.register_component(var, config)
await sensor.register_sensor(var, config)
sen = await cg.get_variable(config[CONF_SENSOR])
cg.add(var.set_sensor(sen))
cg.add(var.set_algorithm(config[CONF_ALGORITHM]))
cg.add(var.set_threshold(config[CONF_THRESHOLD]))
cg.add(var.set_lag(config[CONF_LAG]))
cg.add(var.set_influence(config[CONF_INFLUENCE]))
cg.add(var.set_epsilon(config[CONF_EPSILON]))
ldo_peakdetect.h
* ESPhome custom component: ldo_peakdetect
* V0.9 LDos 16/02/22: initial version
* use smoothed Z-score algorithm
* see: https://stackoverflow.com/questions/22583391/peak-signal-detection-in-realtime-timeseries-data/
#pragma once
// INCLUDES
#include "esphome/core/component.h"
#include "esphome/components/sensor/sensor.h"
// NAMESPACES OPEN
namespace esphome {
namespace ldo_peakdetect {
// GLOBALS
enum LdoPeakDetectAlgo {
COMPARE,
NORMAL,
// DEFINE CLASS
class LdoPeakDetect : public Component, public sensor::Sensor {
public:
// INITIALISATION
LdoPeakDetect() {}
// destructor
~LdoPeakDetect () {
delete data_;
delete avg_;
delete std_;
// PUBLIC METHODS
void set_sensor(Sensor *sensor) { sensor_ = sensor; }
void setup() override;
// bool algorithm: true = common algorithm; false: adapted: only compare deviation to threshold
void set_algorithm(LdoPeakDetectAlgo algorithm) {
algorithm_ = algorithm;
// int lag: size of window to include past signals (e.g. 30-50)
void set_lag(int lag);
// int threshold: if new value is more then threshold*(stdev) away from avg: give signal (e.g. 2-5)
void set_threshold(int threshold) {
threshold_ = threshold;
// float influence: z-score at which the algorithm signals; 0: no influence from previous signals to 1: most influence (e.g. 0.6)
void set_influence(float influence) {
influence_ = influence;
// float epsilon: minimal stdev to detect e.g. 0.05
void set_epsilon(float epsilon) {
epsilon_ = epsilon;
// initialise counter (mean calculation)
void resetBuffers ();
// return status (peak)
int getStatus ();
// return status (edge)
int getEdge ();
// return last data point filtered by the moving average
float getFilteredPoint ();
void dump_config() override;
float get_setup_priority() const override {
return setup_priority::DATA;
protected:
// PROTECTED VARIABLES
sensor::Sensor *sensor_;
LdoPeakDetectAlgo algorithm_; // mode: false = adapted, true = normal
int lag_ = 0; // smoothed z-score pars
int threshold_ = 0; // smoothed z-score pars
float influence_ = 0.0; // smoothed z-score pars
float epsilon_ = 0.0; // smoothed z-score pars
// peak detection algo
int index_ = 0; // current index in value buffer
int status_ = 0; // convert signal to 0: between, 1: positive pulse; -1: negative pulse
int status_prev_ = 0; // status value previous iteration
int edge_ = 0; // status has changed 10: -1 nr 1, 5: 0 nr 1, 1: -1 nr 0, -10: 1 nr -1, -5: 0 nr -1, -1: 1 nr 0, 0: unchanged
float * data_; //
float * avg_; //
float * std_; //
float deviation_; //
float deviationcmp_; //
// PROTECTED METHODS
// calculate square mean of (part of) buffer
float calcSqrMean (int start, int len);
// calculate average of (part of) buffer
float calcAvg (int start, int len);
// calculate standard deviation of (part of) buffer
float calcStd (int start, int len);
void process_(float value);
private:
// NAMESPACES CLOSE
} // namespace ldo_peakdetect
} // namespace esphome
ldo_peakdetect.cpp
// INCLUDES
#include "ldo_peakdetect.h"
#include "esphome/core/log.h"
// NAMESPACES OPEN
namespace esphome {
// GLOBALS
static const char *const TAG = "LdoPeakDetect";
// CLASS
// PUBLIC METHODS
// SETUP
void LdoPeakDetect::setup() {
this->sensor_->add_on_state_callback([this](float value) { this->process_(value); });
if (this->sensor_->has_state())
this->process_(this->sensor_->state);
// LOOP
void LdoSensor01::loop() {
// no action here
void LdoPeakDetect::dump_config() {
LOG_SENSOR("", TAG, this);
ESP_LOGCONFIG(TAG, " Algorithm: %d", this->algorithm_);
ESP_LOGCONFIG(TAG, " Lag: %d", this->lag_);
ESP_LOGCONFIG(TAG, " Threshold: %d", this->threshold_);
ESP_LOGCONFIG(TAG, " Influence: %.3f", this->influence_);
ESP_LOGCONFIG(TAG, " Epsilon: %.3f", this->epsilon_);
void LdoPeakDetect::set_lag(int lag) {
lag_ = lag;
data_ = new float [lag_ + 1];
avg_ = new float [lag_ + 1];
std_ = new float [lag_ + 1];
resetBuffers();
// initialize values and lists
void LdoPeakDetect::resetBuffers () {
for (int i=0; i<lag_; ++i) {
data_[i] = 0.0;
avg_[i] = 0.0;
std_[i] = 0.0;
index_ = 0;
status_ = 0;
status_prev_ = 0;
edge_ = false;
int LdoPeakDetect::getStatus () {
return status_;
int LdoPeakDetect::getEdge () {
return edge_;
float LdoPeakDetect::getFilteredPoint () {
int i = index_ % lag_;
return avg_[i];
// process callback method
void LdoPeakDetect::process_(float value) {
if (std::isnan(value)) {
this->publish_state(NAN);
return;
status_prev_ = status_;
status_ = 0;
int i = index_ % lag_; // current index
int j = (index_ + 1) % lag_; // next index
deviation_ = value - avg_[i];
if (algorithm_==LdoPeakDetectAlgo::NORMAL) {
deviationcmp_ = threshold_ * std_[i]; // "enough" deviation
} else {
deviationcmp_ = threshold_; // "enough" deviation
if (deviation_ > deviationcmp_) {
data_[j] = influence_ * value + (1.0 - influence_) * data_[i]; // store value, influenced by previous
status_ = 1;
} else if (deviation_ < -deviationcmp_) {
status_ = -1;
} else {
data_[j] = value; // store value
avg_[j] = calcAvg(j, lag_);
std_[j] = calcStd(j, lag_);
index_++;
if (index_ >= 16383) { //2^14
index_ = lag_ + j;
// set edge detection from current and previous status
if (status_==1) {
if (status_prev_==0) {
edge_ = 5;
} else if (status_prev_==-1) {
edge_ = 10;
} else {
edge_ = 0;
} else if (status_==-1) {
edge_ = -5;
} else if (status_prev_==1) {
edge_ = -10;
} else {
edge_ = 0;
} else { // status_==0
edge_ = -1;
edge_ = 1;
} else {
edge_ = 0;
ESP_LOGD(TAG, "'%s' - Result %d", this->name_.c_str(), status_);
this->publish_state(status_);
float LdoPeakDetect::calcSqrMean (int start, int len) {
float value = 0.0;
for (int i=0; i<len; ++i)
value += data_[(start + i) % lag_] * data_[(start + i) % lag_];
return value / len;
float LdoPeakDetect::calcAvg (int start, int len) {
float value = 0.0;
value += data_[(start + i) % lag_];
return value / len;
float LdoPeakDetect::calcStd (int start, int len) {
float x1 = calcAvg(start, len);
float x2 = calcSqrMean(start, len);
float powx1 = x1 * x1;
float std = x2 - powx1;
if (std > -epsilon_ && std < epsilon_) {
return 0.0;
} else {
return sqrt(std);
// NAMESPACES CLOSE
