I’m looking into using Home Assistant as a thermostat for a space heater. I’m wondering if it’s possible to link HA to Google Home in a way where GH thinks there’s a thermostat, and it would provide control similar to what you would see with an actual smart thermostat.
I’m very surprised the template climate entities can’t be exposed to GH.
I have a few climate entities that controls the TRV climate entities, and the TRV climate entities are exposed but not the template climate entities.
I don’t have a need for it but this made me look it up
AVAILABLE DOMAINS
Currently, the following domains are available to be used with Google Assistant, listed with their default types:
alarm_control_panel (arm/disarm)
camera (streaming, requires compatible camera)
group (on/off)
input_boolean (on/off)
input_select (option/setting/mode/value)
scene (on)
script (on)
switch (on/off)
fan (on/off/speed percentage/preset mode)
light (on/off/brightness/rgb color/color temp)
lock
cover (on/off/set position)
media_player (on/off/set volume (via set volume)/source (via set input source)/control playback)
climate (temperature setting, hvac_mode)
vacuum (dock/start/stop/pause)
sensor (temperature setting for temperature sensors and humidity setting for humidity sensors)
humidifier (humidity setting/on/off/mode)
