I’ve got a smart dimmer relay from Fibaro in a room installed in the wall, on top of it a regular rocker button
With a regular light bulb, I could just hold down the button and the bulb would slowly dim or brighten. Now I wanted to change to smart light bulb from Innr to also create some color scenes as well as be able to dim. Is it somehow possible to continue using this smart dimmer to also dim a light bulb? It would probably need to have its “actual” dimming functionality (reducing electrical current) deactivated somehow and should instead simply send a signal to HA and HA then in turn send a dimming signal to the bulb for it to work, right?
