I have created a touch panel dashboard, using Brower mod to lock down the interface . No header , no side panel. A restricted interface . If a user click into a entity and show more info , he can then press a show more link , which takes the user to history. Unfortunately the user is now stuck , as the interface is locked down. I know I can restrict more info with actions , but the graphs an extra info are useful, is there anyway of removing or disabling the “show more” link ?
It should be possible using a card-mod theme. Check out Thomas’s example where he completely alters the home assistant interface.
hey, did you find a solution?
