Is it possible to show group panels next to each other, instead of beneath each other?
The config below produces two plain Google Map panels, I’d like to have them displayed inside two white blocks with a title. I’ve also tried to seperate them in different groups, this was something I found elswhere in the forum.
Ahh cool, maybe I can create a custom HTML page with this and include it in Hass. I also have a idea how I can get the info in the html page…
All the location info is available in the Home Assistant log, so I can extract this with a script
The below example is in Powershell, but I should be able to convert it to whatever else. It is just a example…
$lines = "cat home-assistant.log | grep 'device_tracker.tel'"
foreach ($line in $lines) {
$regex = (?=device_tracker)\w+ # just a quick start, not a complete regex..
$match = $line($reggex)
# create object with name tel_1 and two members (lat/long)
But if I create a extra external page in Hass, can I be sure that non-authenticated users can not access the page??
Oh and is there some information available what languages are supported when I would like to create a custom dynamic page? I don’t think I can use php in the docker container…
This does looks like a fun mini-project for a Hass newbie
Hass uses js and css. You could use your own, but i’m not sure how that would interact. If you know php or any language, learning js and css isn’t bad. I don’t know it and I was able to read and write it. I think you could just do a custom panel instead of another page. You could also use appdaemon and hassdashboard.
