Is it possible to get values that from deConz aren't shown in Home assistant? (TS011F - _TZ3000_w0qqde0g)
I have a zigbee smart plug (TS011F - _TZ3000_w0qqde0g) that supports energy metering but those values aren’t shown in Home assistant.
If i read the values from deConz interface it seems to register energy metering too Immagine
Is there a way to create some sort of virtual device to use those values on Home Assistant?
Thank you
It is :slight_smile: you may need to add custom DDF file, or wait for new deconz addon version - 2.14.1 which should have proper DDF for those plugs - DDF for Neo NAS-WR01B #5577
Is there some sort of guide to edit the DDF? the 2.14.1 version is out but HA still doesn’t support the energy metering, event if from deconz seems to be exposed:
Bump* (same issue here)
Yo estoy igual, tenéis alguna solución?
No, I switched to ZigBee2mqtt and it works without any customization
Anyone got them working with deConz? I have similar devices (TS011F _TZ3000_gvn91tmx) and I observe exactly the same behavior - power is shown in deConz/VNC but appearently not disclosed to HA.
Same here. There is someone who apparently managed it to get it working, yet I have no idea how that was done.
