As in subject. Thanks!
That would be awesome
How did it turn out?
Any news? Are you still on it? I would love to run everything on the same PI.
I asked a few weeks ago and got no responseā¦
I am also interested!
Iām very interested also
Interested too.
Interested too.
I just installed this onto another Pi ( that is already running PiHole in addition), went straight on and works brilliantly ).
Would recommend PiHole also!
Same settings
What is it that you installed exactly, apart from PiHole ?
Grab your Pi ( or virtual linux machine ) any linux based host⦠and follow this video, this will provide you network level Advert blocking⦠no additional plugins needed for pads or mobiles ![]()
When that is done: You can install PiVPN
Information,
http://www.pivpn.io
to install from command line⦠( remove ā| bashā ) to see what it doesā¦
curl -L https://install.pivpn.io | bash
Follow the prompts⦠All done, nice and easy.
You can then download the OpenVPN on a PC and connect directly after you made a certificate for each device. -very easy.
Or you can just install PiVPN if you dont want PiHole.
Ah, right⦠All nice and dandy, but none of that will work in HASSio. Thanks anyway.
PiVPN/PiHole may be port-able to a Docker unit in HASSIO, but thatās beyond my skill set,
so I just used a secondary PI.
Some paths to start from.
Docker image:
Fork from previous project with support for multiple users:
I have never done this before, but after reading the home assistant documentation, it doesnāt seem so hard. Will give it a try if I find some time.
Docs:
any luck with creating the addon for vpn?
Would be great!
I am also very interested in a VPN addon!
@takje would be awesome!
