Is it possible to implement a command upon pressing a tile?
I would have some uses: first the possibility to click on a camera stream and increase the size of the view (it could be also a navigate command to open another dahboard that has a bigger view of the camera stream)
The JavaScript widget will allow you to run any javascript command.
but the widget is either camera or javascript … ?
general commands is impossible, because it would override existing click functions.
but you are welcome to try to create a general command. you can create your own general javascripts in a custom skin.
in a couple of years I probably will be able to
