Egoman
July 14, 2021, 9:36am
1
I have a sonoff mini that is in the ceiling for a light. At the moment it appears as switch. in home assistant but I’d prefer it to be a light. since it is a light in this instance. Is this possible?
I believe this can be done in Home Assistant itself but I like to keep all the changes together so not to get confused if and when I improve or update stuff later on.
This is my current config if it helps
substitutions:
ip_address: 192.168.1.XX
gateway_address: 192.168.1.1
subnet_address: 255.255.255.0
dns1_address: 192.168.1.1
dns2_address: 192.168.1.1
timeout_reboot: 5min
devicename: bedroom2_light_ceiling_sonoff_mini
upper_devicename: Bedroom2 Light Ceiling
ap_name: bdrm2_ceil_lght
esphome:
platform: ESP8266
board: esp01_1m
# WiFi connection
wifi:
networks:
- ssid: !secret wifi_ssid_NoT
password: !secret wifi_password_NoT
priority: 10
#enable acess point access if no wifi
ap:
ssid: $ap_name
password: !secret ota_password
manual_ip:
static_ip: $ip_address
gateway: $gateway_address
subnet: $subnet_address
dns1: $dns1_address
dns2: $dns2_address
reboot_timeout: $timeout_reboot
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret api_password
# Enable over-the-air updates
ota:
# Enable Web server
web_server:
port: 80
# Sync time with Home Assistant
time:
- platform: homeassistant
# Text sensors with general information
text_sensor:
- platform: version
- platform: wifi_info
ip_address:
ssid:
bssid:
# Uptime sensor
- platform: uptime
# WiFi Signal sensor
- platform: wifi_signal
name: $upper_devicename wifi signal
update_interval: 10s
status_led:
pin:
number: GPIO13
inverted: true
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
filters:
- invert:
- delayed_off: 10ms
on_press:
- switch.toggle:
- platform: gpio
#name: $upper_devicename switch
pin: GPIO04
on_press:
then:
- switch.toggle:
# on_release:
# then:
# - switch.toggle:
# id: relay_1
switch:
- platform: gpio
icon: "mdi:lightbulb"
pin: GPIO12
restore_mode: ALWAYS_OFF
Thank you.
nickrout
(Nick Rout)
July 14, 2021, 9:39am
2
Yes, use the binary light component
IgorZg
(Igor Simić)
July 14, 2021, 9:49am
3
You can define light as following template:
lights:
# Moes switch ured
moes_wall_switch_03_01:
friendly_name: "Ured 1/1"
unique_id: moes_wall_switch_03_01
level_template: >-
{% if is_state('switch.moes_wall_switch_03_01','on') %}255{% else %}0{% endif %}
value_template: >-
{{ is_state('switch.moes_wall_switch_03_01','on') }}
turn_on:
service: switch.turn_on
entity_id: switch.moes_wall_switch_03_01
turn_off:
service: switch.turn_off
set_level:
service_template: >-
{% if brightness > 0 %}switch.turn_on{% else %}switch.turn_off{% endif %}
entity_id: 'switch.moes_wall_switch_03_01'
I did this for all my light switches.
Egoman
July 14, 2021, 9:59am
4
Thank you for your help, however my knowledge is not great on this as you can probably tell.
Would I need to change my switch to a output and then add the binary light code?
Egoman
July 14, 2021, 10:00am
5
Thank you for you help however this is exactly the complexity I’m trying to avoid.
Replace the above with:
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: relay_1
You’ll alswo need to change - switch.toggle:
to - light.toggle:
Egoman
July 14, 2021, 12:22pm
7
Thank you again for your help with this.
So I changed this as you have described
substitutions:
esphome:
platform: ESP8266
board: esp01_1m
# WiFi connection
wifi:
networks:
priority: 10
ap:
ssid: $ap_name
manual_ip:
dns1: $dns1_address
dns2: $dns2_address
# Enable logging
logger:
api:
ota:
# Enable Web server
web_server:
port: 80
time:
text_sensor:
- platform: version
ip_address:
ssid:
bssid:
# Uptime sensor
- platform: uptime
status_led:
pin:
number: GPIO13
inverted: true
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
filters:
- invert:
- delayed_off: 10ms
on_press:
- light.toggle:
- platform: gpio
pin: GPIO04
on_press:
then:
- light.toggle:
# on_release:
# then:
# - light.toggle:
# id: relay_1
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: relay_1
but I’m getting this error on the change from - switch.toggle:
to - light.toggle:
ID ‘relay_1’ of type gpio::GPIOBinaryOutput doesn’t inherit from light::LightState. Please double check your ID is pointing to the correct value.
Egoman
July 14, 2021, 12:31pm
8
I think I have it working now - I added an id to the light and the error are gone. Just trying now. I’ll report back once I’m sure. Thanks
Egoman
July 14, 2021, 12:42pm
9
So this is the final esphome code that I used on my sonoff mini to display in home assistant as a light instead of a switch.
substitutions:
esphome:
platform: ESP8266
board: esp01_1m
# WiFi connection
wifi:
networks:
priority: 10
- ssid: !secret wifi_ssid_gif
password: !secret wifi_password_gif
priority: 20
- ssid: !secret wifi_ssid_bc
password: !secret wifi_password_bc
priority: 30
ap:
ssid: $ap_name
manual_ip:
dns1: $dns1_address
dns2: $dns2_address
# Enable logging
logger:
api:
ota:
# Enable Web server
web_server:
port: 80
time:
text_sensor:
- platform: version
ip_address:
ssid:
bssid:
# Uptime sensor
- platform: uptime
status_led:
pin:
number: GPIO13
inverted: true
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
filters:
- invert:
- delayed_off: 10ms
on_press:
- light.toggle: light_1
- platform: gpio
pin: GPIO04
on_press:
then:
output:
- platform: gpio
pin: GPIO12
light:
- platform: binary
output: relay_1
Thank you Holdesmade for your help as I wouldn’t of been able to do this without it.
Yes sorry, you’re right. Glad its working
marek76
(marek)
July 12, 2023, 11:33pm
11
this is my modified code and compiled for sonoff TX switches
from two users of this forum
I’m sorry I don’t know who the other one was
if it helps anyone
substitutions:
devicename: yours_name
upper_devicename: yours-name
esphome:
# Automation turning on the blue status LED once T1 is booted up
on_boot:
priority: -10
then:
- light.turn_on: blue_led_light
esp8266:
board: esp01_1m
wifi:
# Enable logging
logger:
api:
ota:
web_server:
port: 80
text_sensor:
- platform: version
ip_address:
ssid:
# Uptime sensor
- platform: uptime
entity_category: "diagnostic"
update_interval: 30s
# Reports the WiFi signal strength in %
- platform: copy
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode:
input: true
pullup: true
inverted: true
name: "Light Touchpad 1"
on_press:
- switch.toggle: relay_1
- platform: gpio
pin:
number: GPIO9
mode:
input: true
pullup: true
inverted: true
name: "Light Touchpad 2"
on_press:
- switch.toggle: relay_2
- platform: gpio
pin:
number: GPIO10
mode:
input: true
pullup: true
inverted: true
name: "Light Touchpad 3"
on_press:
- switch.toggle: relay_3
- platform: status
switch:
- platform: gpio
name: "Light Relay 1"
pin: GPIO12
- platform: gpio
name: "Light Relay 2"
pin: GPIO5
- platform: gpio
name: "Light Relay 3"
pin: GPIO4
output:
# Register the blue LED as a dimmable output ....
- platform: esp8266_pwm
pin: GPIO13
inverted: true
light:
# ... and then make a light out of it.
- platform: monochromatic
name: "Light Blue LED"
output: blue_led
internal: true
