gwpt
(Guy Taylor)
August 22, 2020, 2:48am
1
I am trying to write a script where I can pass in an entity and a input_select as parameters and use them inside. This would allow this script to be resused for multple entities.
Here’s the code snippet:
Script:
save_study:
sequence:
- service: input_select.select_option
data_template:
entity_id: "{{ select }}"
option: >-
{%- if is_state('{{ light }}', 'on') -%}
on
{%- else -%}
off
{%- endif -%}
Caller:
- service: script.save_study
variables:
select: input_select.study_ceiling_light_state
light: light.study_ceiling
But it doesn’t seem to work… The version without the variables does, i.e. this code:
save_study_old:
sequence:
data_template:
entity_id: input_select.study_ceiling_light_state
option: >-
{%- if is_state('light.study_ceiling', 'on') -%}
on
{%- else -%}
off
{%- endif -%}
Is it just to possible? or am I using the variables wrong/wrong syntax?
thx
In your caller script, remove the variables line. It is not needed.
Everything else looks fine.
Yep, variables
is only needed if calling the script via script.turn_on
. See the following for more details about the differences between calling a script “directly” (i.e., using its entity_id as the service) and “indirectly” (i.e., using the script.turn_on
service):
Passing Variables to Scripts
Waiting for Script to Complete
gwpt
(Guy Taylor)
August 22, 2020, 4:48am
4
As an FYI I needed to change it to the following:
save_study:
sequence:
data_template:
entity_id: "{{ entityparam }}"
option: >-
{%- if is_state(lightparam, 'on') -%}
on
{%- else -%}
off
{%- endif -%}
entityparam: input_select.study_ceiling_light_state
lightparam: 'light.study_ceiling'
Thanks for the help!
gwpt
(Guy Taylor)
August 22, 2020, 5:04am
5
Another issue…
I’m trying to do a similar thing in a service_template
restore_light_state:
sequence:
- service_template: >
{% if is_state(entityparam, "on") %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: "{{ lightparam }}"
calling with:
- service: script.restore_light_state
lightparam: light.study_ceiling
but I get the following error:
restore_light_state: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
Yet:
sequence:
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: light.study_ceiling
Works fine. So there is somethere in the substiation of the line:
It doesn’t like. What’s weird is that works in the previous example…
gwpt
(Guy Taylor)
August 22, 2020, 7:26am
6
Ok, i fixed it… The data section needed to be a data_template:
sequence:
light.turn_on
{% else %}
light.turn_off
{% endif %}
data_template:
entity_id: "{{ lightparam }}""
