Is it possible to play a specific movie on kodi via hass script?
I would like to create a view for my kid, where he is presented with a selection of movies he can choose from and play via KoDi.
For this, I am missing one key ingredient:
How can I play a specific movie from my KoDi library? I would need to know if and where I can find a kodi movie ID which command I need to use to play it.
Can anyone help?
Http://kodi.tv
Please elaborate
The API is best asked about on the kodi forum.
oh, thanks so much…
OK, I figured out a working solution (not sure if it is the optimal way but it works):
Create RESTful Commands for each Kodi movie. One examples is as follows:
rest_command:
  kodi_moviename:
    url: 'http://KODIHTTPIP:KODIPORT/jsonrpc'
    method: post
    username: !secret kodi_username
    password: !secret kodi_password
    payload: '{"jsonrpc":"2.0","id":"1","method":"Player.Open","params":{"item":{"file":"smb://YOURFILESHAREIP/PATH/FILENAME"}}}'
    content_type: 'application/json'
Then create a script for each movie for manually triggering it via HASS GUI:
SCRIPTNAME:
  alias: Play Movie ABC
  sequence:
    - service: rest_command.kodi_moviename
I then added SCRIPT Tiles to tileboard which are linked to the scripts created above and are represented by movie posters images.
Maybe this helps someone with a similar aim. Enjoy and feel free to give expert opinion on how to do it easier, as I am a hass n00b :grinning:
And I actually did find an easier method, by using the HASS kodi call method as script for each movie. So you don’t have to write the RESTful command, but only a script entry for each movie:
movie_xy:
  alias: Play Movie XY
  sequence:
    - service: media_player.kodi_call_method
        entity_id: media_player.kodi
        method: Player.Open
        item:
          file: "smb://YOURFILESHAREIP/PATH/FILENAME"
the only caveat with this approach, though, is that you must add the kodi component to the config yaml, whereas the RESTful command, directly would communicate with kodi.
But how to specify files that are already on the internal memory?
developer-tools/service: kodi.call_method
  "entity_id": "media_player.kodi",
  "method": "Player.Open",
    "item": {
      "file": "file:///home/xbian/lift.strm"
There is no error on home-assistant but an error on KODI.
I found the correct answer: /home/xbian/lift.strm
I know this thread is getting old, but I’m trying to take this idea a bit further. I would like to be able to say to my Google Home “Tell Kodi to play XYZ” and this will cause Kodi to play that movie. So far I have two scripts, one that searches for a movie with a given string and returns a single result with the movieid from the database, and another that plays a movie given a specified movieid. These two scripts work perfectly. The issue happens when I try to use an automation to run the second script based on event data from the first script. As far as I can tell the issue is that the template is returning a string instead of an integer but I’ve tried changing it to an integer and it doesn’t help. See relevant code below.
The two scripts
'1593263499843':
  alias: Kodi Get Movie
  sequence:
  - data:
      entity_id: media_player.living_room_tv
      filter:
        field: title
        operator: contains
        value: minions
      limits:
        end: 1
        start: 0
      method: VideoLibrary.GetMovies
'1593279336491':
  alias: Kodi Play Movie
  sequence:
  - data_template:
      item:
        movieid: '{{ movieid|int}}'
      method: player.open
The automation:
- id: '1593279263626'
  description: ''
  - event_data:
      input:
    event_type: kodi_call_method_result
    platform: event
  condition: []
  - data_template:
      movieid: '{{ trigger.event.data.result.movies.0.movieid|int }}'
    service: script.1593279336491
and here is the JSON response I get from the second script.
    "event_type": "kodi_call_method_result",
    "data": {
        "entity_id": "media_player.living_room_tv",
        "result": {
            "code": -32602,
            "data": {
                "stack": {
                    "message": "Received value does not match any of the union type definitions",
                    "name": "item",
                    "type": "object"
            "message": "Invalid params."
        "result_ok": false,
        "input": {
            "method": "player.open",
            "params": {
                "item": {
                    "movieid": "434"
    "origin": "LOCAL",
    "time_fired": "2020-06-27T19:42:26.248254+00:00",
    "context": {
        "id": "44a317e2601f4bd183e99b352abe675c",
        "parent_id": null,
        "user_id": null
In case this helps anyone:
i got @noogs approach to work by returning the file path from the search and modifying the Player.Open call accordingly (maybe there’s a more elegant version out there but this works):
Here is the final get movie script (notice the properties: object )
'1593263499843':
  sequence:
  - data:
        filter:
          field: title
          operator: contains
          value: minions
        limits:
          end: 1
          start: 0
        properties:
          - file
the automation just passes the path to the script:
- id: '1606993440700'
  alias: OnMovieFound
  description: ''
  - platform: event
    event_data:
      result_ok: true
      input:
  - service: script.play_movie_in_kodi
    data_template:
      file: '{{ trigger.event.data.result.movies.0.file }}'
  mode: single
and the script:
play_movie_in_kodi:
    data_template:
      item:
        file: '{{ file }}'
      method: Player.Open
      entity_id: media_player.libreelec
