I restored an old instance of home assistant, but I do not have the ST personal access token that was used in that HA instance. I am having trouble installing the ST integration and believe that I need to use hass_smartthings_remove PERSONAL_ACCESS_TOKEN
to remove the old instance completely, but obviously that is a problem if I don’t know the token.
Is there a way to recover this token or to completely remove the integration without knowing it? I’ve already tried deleting the smartthings file from .storage
