After creating a ZHA / Zigbee group, is there any way to rename them? Or is it a case of deleting and remaking?
Thanks.
Thanks.
You can do it, but you have to go to ZHA, then click on the coordinator under devices, here you will see your groups as lights.
Click any of them and then the cog wheel to rename.
Or just search for the entities and rename them the same way.
With that method the group will only get “half renamed”.
In the zigbee group list (and in the “Manage Zigbee device” section of each device) the group will still be named as of the old name.
Seems the functionality “also rename in Home Assistant” is missing. Does that mean, that deleting the old group and creating a new group is the only way?
According to [Feature request]: Rename Group updates in Home Assistant entity ID · Issue #18783 · Koenkk/zigbee2mqtt · GitHub it should be possible to change the entity IDs within HASS, but I don’t know how.
