Hello
I have a lite project in Django and my question is: Can I run a docker image inside hassio?.
I used the image for the raspberry pi 3
Hello
No, when using then hassio image you can’t run anything else on the RPi other than apps available thru the add-ons.
if you want to be able to run other apps in docker then you need to use the alternative install method in a generic Linux server.
You can pull another docker image though… Just use Portainer.
really? I didn’t realize that.
I was always under the impression from the many threads here that Hassio was fairly locked down and limited to what could be run outside of hassio and the available add-ons.
If that’s the case then what is the benefit of installing hassio in a generic server outside of using the official hassio image, then just using portainer to work outside of hassio?
Well if you want to install non-docker stuff for instance.
Oh, Ok.
I never heard that there was any distinction. I guess it makes sense tho.
Thanks for the info.
How i can do this? I intalled Portainer, but when i want to pull image. The image is not created and does not throw any error.
For example:
What OS are you on?
