Is it possible to run a http url on the local HA machine (RPi)?
I have a webcam server running on my home network. I need to be able to send a local http command on the server to reset the camera server when it stops working. I have a Tap action button set up in the UI which allows me to run the url but only on the client machine where I active the button. This does not work on all clients as I have some firewalll issues when I do that on my work PC.
So ideally im looking to run the command locally from the RPi…any help or advise please.
type: custom:button-card
name: Restart Cam Server
tap_action:
  action: url
  url_path: >-
    http://myDNS:8083/axis-cgi/admin/restart.cgi?&user=<myusername>&pwd=<mypassword>
You’re looking for a RESTfull command
A little hijack but really on topic and it might help: I would like to do something similar and have tried this but cannot get it to work.
I have a RPi (not my HA) that I have to reboot sometimes.
If I do that from a browser, this is the URL to do so: http://172.16.0.23/cgi-bin/main.cgi?ACTION=reboot
This is what I tried:
rest_command:
  reboot_rpi:
    url: "http://172.16.0.23/cgi-bin/main.cgi"
    method: put
    content_type: "application/x-www-form-urlencoded"
    payload: "ACTION=reboot"
Also tried:
url: "http://172.16.0.23/cgi-bin/main.cgi?ACTION=reboot"
Hi Nick,
This is my HA restart automation:
alias: "SYSTEM: Restart Home Assistant"
description: ""
  - platform: time
    at: "09:30:00"
  - platform: time
    at: "23:00:00"
condition: []
  - service: homeassistant.restart
    data: {}
mode: single
And from the ui with a custom button card:
tap_action:
  action: call-service
icon: mdi:power
color: rgb(255, 0, 0)
lock:
  enabled: true
  color: black
I used a custom button card so that it can have a button lock on it…requires a double tap to actually activate the button and restart the HA
But to get the rest full command to work I made a “reset_webcam_server.yaml” file with this:
rest_command:
  reset_webcam_server:
    url: "http://192.168.100.210:8083/axis-cgi/admin/restart.cgi?&user=admin&pwd=mypassword"
Then I used a time automation to operate it:
alias: "CAMERAS: Reset Webcam Server at 06:00 daily"
description: ""
  - platform: time
    at: "06:00:00"
condition: []
  - service: rest_command.reset_webcam_server
    data: {}
mode: single
