Is it possible to save my haos install and put it on a docker installation?
I need to use the host’s gpio to control some relays and whatnot, and what i have seen it is easier to use a docker install. can i move the os into a docker one? any help appreciated.
(I am on a rpi 4 with 4gb ram)
Create a backup. Copy it off your system and inspect it to ensure the contents are correct.
Set up your Docker install.
Copy the config folder and everything in it (including hidden folders) to your Docker install and restart.
Set up any containers you need to replace addons that you had.
