Pirol62
(Jörg Nauen)
August 5, 2022, 2:10pm
1
Use_case: I don’t want to send a command when it is not necessary.
So when the cover is already open, then do nothing.
- choose:
- conditions:
- condition: template
value_template: "{{ state_attr('cover.rollo_sz_fenster_klein','current_position') | int(default=0) < 100 }}"
sequence:
- service: cover.open_cover
entity_id: cover.rollo_sz_fenster_klein
- delay: "00:02:00"
- choose:
- conditions:
value_template: "{{ state_attr('cover.rollo_fitnessraum','current_position') | int(default=0) < 100 }}"
sequence:
entity_id: cover.rollo_fitnessraum
- delay: "00:02:00"
- choose:
- conditions:
value_template: "{{ state_attr('cover.rollo_gastezimmer','current_position') | int(default=0) < 100 }}"
sequence:
entity_id: cover.rollo_gastezimmer
jchh
(my username is my initials (and my first name isn't John))
August 5, 2022, 2:34pm
2
I don’t think you can use a for() loop in an automation
{% for i in range(1, 3) %}
{% endfor %}
…so perhaps make a script and call it 3 times?
Is the delay necessary for the covers to open?
Otherwise, you could create a covers group from your covers, then use the expand
function to select only the relevant covers (i.e. those whose current_position
attribute is <100) under a single service call - HA allows you to supply a list for the entity_id
key.
I can give you an example if you’re interested.
Pirol62
(Jörg Nauen)
August 5, 2022, 3:04pm
4
The delay is in order to avoid overutilizing the duty cycle. Otherwise it would have been simpler with group indeed
Pirol62
(Jörg Nauen)
August 5, 2022, 3:07pm
5
You’re right. A loop but as well as scripts doesn’t make things better.
It seams, that there is no other way to shorten this.
You should be able to use the Repeat For Each action…
- repeat:
for_each:
- "rollo_gastezimmer"
- "rollo_fitnessraum"
- "rollo_sz_fenster_klein"
sequence:
- condition: numeric_state
entity_id: 'cover.{{ repeat.item }}'
attribute: current_position
below: 100
- delay: '00:02:00'
Pirol62
(Jörg Nauen)
August 6, 2022, 6:06am
7
Hey, that’s it! Thank you. That looks much smarter.
PS:
That did not work.
This part is not allowed:
below: 100
2022-08-06 09:03:58 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: Entity cover.{{ repeat.item }} is neither a valid entity ID nor a valid UUID for dictionary value @ data['action'][0]['repeat']['sequence'][0]['entity_id']. Got None. (See /config/configuration.yaml, line 28).
weird. I use something similar very successful:
- service: media_player.volume_set
entity_id: "media_player.{{ state_attr('variable.active_alarm_target','alias') }}"
volume_level: 0.1
All parts of the Service action are templatable, but that’s not true about every part of automations and script. Sometimes it’s hard to remember exactly which fields of which functions will or won’t accept templates.
Try it as a template condition instead…
- repeat:
for_each:
sequence:
value_template: >
{% set entity = 'cover.'~ repeat.item %}
{{ state_attr(entity, 'current_position') < 100}}
- delay: '00:02:00'
