Is it possible to trigger on a HA update available?
I’m wondering is it possible to trigger on new HA update available in NodeRED?
Check out the version integration. Create one sensor for installed version:
  - platform: version
    name: HASS Installed
and one sensor for available version (with the config for your installation type):
  - platform: version
    name: HASS Available
    source: docker
    beta: true
These are examples from my setup. Then in Node-Red do something whenever the available version sensor changes and if it is larger than the installed version, then send a message. I don’t use Node-Red so can’t help you with the details for the automation, but I assume it should be straightforward.
Thanks. This wil help
