Is it possible to turn on an integration?
Hi everyone, i managed to succesfully setup the Ultra Connect integration (here’s the github page) and it works amazing, the only problem is that the alarm supports maximum 1 connection per time, so if the integration is connected i can’t use my app on the phone… is it possible to turn the integration on and off with an automation or similar?
The integration would need to provide a service you could use to enable and disable it. I’d open an issue with the developer about that.
