Hope I didn’t miss the obvious…I can’t seem to find a way to arm Ring motion alert (similar to arming Blink) based on presence?
Thanks.
Thanks.
Are you trying to turn ON RING app notification based on home/nothome?
I use ring sensor then trigger html5 notification with RING motion alert. I’m sure you can do this and just turn ON/OFF notification based on presence.
I am sure you cannot control app or RING notification since this is one time setting and per device individual setting
Thanks, I’m trying to see if HA could switch on/off the Motion Alerts as seen attached/below based on presence status (home/not_home)!
Screenshot_20181210-140811%5B1%5D|243x500
Hi Quattr0,
Did you find a solution for this?
My idea was to turn on notification only when the Yale lock at the front door is locked.
No I have not.
Too bad
Thanks for answearing thou, much appreciated.
Just curious if anyone has yet managed to find a way of enabling/disabling motion alerts from within HomeAssistant?
