some time i receive this kind of message " Login attempt failed " no idea why. when i check ip address it’s not mine. do i need to worry?
Yes someone is trying.
https://www.abuseipdb.com/check/111.7.96.172?page=1#report
Make sure you have a strong password and enable multi-factor authentication. Then you have little to worry about.
Also consider an alternative remote access method that does not rely on port forwarding. Like a VPN or Nabu Casa.
thanks for info…
How do you enable multi-factor authentication for Home Assistant?
