Is it worth moving from the Blue to Green or Yellow?
I’ve hit a ceiling with my Electrolama zzz! zigbee stick (144 devices) and so will be changing and seeing as I’m going to make a lot of work for myself, should I consider going from the Blue to either the Green or Yellow? Is it worth it?
And which Zigbee stick? Something Ethernet or PoE?
Changing from Blue to Green or Yellow won’t do a thing for your Zigbee problems.
A coordinator based on the EFR32MGM24 should work with a network of 300 devices (but since you will switch from zstack to ember, prepare the switch carefully)
The CC6252P7 also has more memory then the CC6252, ans so can handle more devices.
I just thought that seeing as I will have the pain of moving to a new coordinator then perhaps I’d also upgrade the HA box too.
Impatient me has gone with a Beelink SER5 Max and a SLZB-MR3 Zigbee and Thread Adapter.
The SLZB-MR3 has both a CC2674P10 and a EFR32MG24, so either way a serious upgrade for the ZZH
