Is mine speedtest executed only at 3 AM every day?
Hi to all,
this is the speedtest component inside my configuration.yaml:
speedtestdotnet:
  scan_interval:
    minutes: 0
    hours: 3
  server_id: 7898
  monitored_conditions:
    - ping
    - download
    - upload
I would test executed only at 3AM, every day.
But, I see in frontend several updates, like this:
Immagine
Atm it’s 2PM, but I can see several updates, I would exepct a flat line since last 3AM, no?
Is there a possibility to log when speedtest start?
You’ve set it to scan every 3 hours.
OK, I understand. How can I set it only at 3AM, every day? Thank you very much for your effort!
You can do this by using an automation as explained in the docs.
Thank you, solved!
