Hi
I would like to know if its possible to have a multi line automation message as I would like to see a few states and in 1 line its very messy.
Ive tried \n and even a + but they dont work
Martyn
Hi
Martyn
There are two ways to use multiline: | and >
You can use a - or a + after it to redact or add an extra line at the end.
action: |
Your actions.
please read this, very useful stuff.
Does this actually work in automation messages as I have tried a couple of different permutations but nothing seems to work ?
message: Outside Temp is {{states.weather.home.attributes.temperature }}
Living Room Temp is {{states.living_room.attributes.temperature}}
Id like both in separate lines
ok. please read this before posting anything else.
to put is short - we cannot help you based only on your words without seeing your code (properly formatted by enclosing it in three back quotes).
adios
Mine work formatted like this:
message: >-
good!
and you want these two lines to be separate, right?
have you read the page I referred you to?
it says “use > if you want newlines inside the block to be replaced by spaces” so it’s a wrong choice.
try message: |
and read that link, it’s very useful.
Yes it is useful thanks, I’ve now changed mine from >- to |- when I need lines separated
Hi
All now working and I now have 1 multi line smart messages that update rather than 5 separate automations.
Thank you
