Hi. Is it possible to set assumed_state to true or false in lambda? I am trying to enable both up and down buttons in case I stop my garage door opening at half, so I would like to have both buttons enabled to have a choice, either I continue opening the garage, or close it. At the moment, if I start opening garage door and stop it mid way, I have to press again “Open cover” to open it fully, only then the “Close cover” button gets enabled.
cover:
device_class: garage
lambda: |-
if(id(bottomSensor).state < 0.25) {
return COVER_CLOSED;
else if(id(topSensor).state < 0.25) {
return COVER_OPEN;
else if(isnan(id(bottomSensor).state) && isnan(id(topSensor).state))
id(cover_garage).assumed_state(true);
else {
id(cover_garage).assumed_state(false);
open_action:
- switch.turn_off: open_switch
close_action:
- switch.turn_off: close_switch
stop_action:
- switch.turn_on: close_switch
- switch.turn_on: open_switch
