Is something seriously wrong?
I have been having lots of issues since upgrading to 101 from ~86. recorder, history, and logger have all stopped working. My home-assistant_v2.db is also almost 11 GB! I’ve tried to purge it but recorder won’t set itself up. Nor will history or logger. I’ve renamed the …db to …db.bak so that it effectively does not exist yet HA does not fix itself and create a new one on restart. I’m on debian and apt-get says sqlite3 is good when i try to install it.
I’m thinking maybe uninstall sqlite and reinstall but that is a bit drastic and may break HA in other ways.
Advice?
Here is my HA log
Setup failed for history: Could not set up all dependencies.
9:06 PM setup.py (ERROR)
Unable to set up dependencies of history. Setup failed for dependencies: recorder
Setup failed for recorder: Integration failed to initialize.
Error during connection setup: No module named ‘_sqlite3’ (retrying in 3 seconds)
9:06 PM components/recorder/init.py (ERROR) - message first occured at 9:05 PM and shows up 10 times
Setup of recorder is taking over 10 seconds.
9:06 PM util/async_.py (WARNING)
How did you install originally?
That is a huge gap to update over. There are a ton of breaking changes since then. Be prepared to do a fresh install.
Yep. All problems solved when I started over with hassio (previously using hassbian). Thanks for the help
