I have this is my configuration.yaml ( only relevant information pasted )
recorder:
purge_keep_days: 21
- platform: systemmonitor
resources:
- type: disk_use
arg: /
- type: disk_use_percent
arg: /
- type: memory_use
- type: memory_use_percent
- type: swap_use
- type: processor_use
- type: processor_temperature
influxdb:
host: 192.168.1.230
port: 8086
database: homeassistant
username: !secret influxdb_user
password: !secret influxdb_password
max_retries: 3
measurement_attr: entity_id
include:
domains:
- sensor
These metric are all transfered to InfluxDB. But disk_use, disk_use_percent and swap_use only seems to add a new point when the value change. Is this correct? Can’t seem to find anything in the docs about this?
These values are also updated when I restart the Pi or supervisor.
I can see why this is done … but it makes my graph look a bit odd
System information:
Raspberry PI 4 with 8GB with an 500GB SSD on USB
Home Assistant Core 2022.5.4
Home Assistant Supervisor 2022.05.2
Home Assistant OS 7.6
Kernel version 5.10.103-v8
Agent version 1.2.1
Path to configuration.yaml: /config
Developed by a bunch of awesome people.
Published under the Apache 2.0 license
Source: server — frontend-ui
Built using Python 3, Lit, Icons by Google and Material Design Icons.
Frontend version: 20220504.1 - latest
