can you call the service to set the volume level of the slider to an increment of 5? I still find it odd that it’s set to a random level inside your env. Mine is constrained to the 5’s with a near configuration. I think that may be the problem.
You can always remove the condition too. It won’t do much other than make a second post of your volume level.
hashing out both the condition blocks seems to get me closer… but im wondering if the conditions are failing due to the calculation of -dB not being quite right:
You’ll see in the image that dragging the slider to 45 doesn’t set the amp to 45, but 42. The scrape sensor is getting the actual dB level via http.
It seems like that would be the problem. And it seems like the problem is on Denon side. That volume level should be perfectly on the 0.0x decimal place. It’s no where near that. Sometimes it falls perfectly, it’s odd. Removing the condition would keep it working. If you’re interested in making it perfect, I need you to get a list of numbers in db, and match it to a list of volume_levels. From there we can tailor the equation to match better. You want to span the whole range. So from min volume to max volume.
thanks @petro. i’ve taken a slightly different route which seems to be exactly what i was after:
i’ve got my input_number as it was:
denon1_receiver:
name: Zone 1 Volume
initial: -80
min: -80
max: 0
step: 5
unit_of_measurement: dB
but the automation for volume control using the slider now triggers the curl command that sends the input_number directly to the receiver without any changes:
