Is template sensor the best option to solve my problem?
Hey guys,
I’ve been trying to come up with a solution to my problem so maybe i’ll start by layout that out first…
I have a Denon receiver which I want to control via Home Assistant. I know there’s a Denon platform already but it doesn’t do what I want, and a couple of times has put the receiver into 100% volume.
Ok so here’s the current state of things:
  • Scrape sensor to pull the current volume level from the receiver via HTTP every 10 secs - works fine:
    #denon
    platform: scrape
    resource: http://192.168.1.113/goform/formMainZone_MainZoneXml.xml
    select: "MasterVolume value"
    unit_of_measurement: dB
    scan_interval: 10
  • 4 shell command lines to use the current volume from the step above and either +10db, -10db, +5db or -5db:
    set_denon_volup_10db: '/usr/bin/curl "http://denon/MainZone/index.put.asp?cmd0=PutMasterVolumeSet%2F{{ states.sensor.denon_volume.state|float + 10 }}"'
    set_denon_voldown_10db: '/usr/bin/curl "http://denon/MainZone/index.put.asp?cmd0=PutMasterVolumeSet%2F{{ states.sensor.denon_volume.state|float - 10 }}"'
    set_denon_volup_5db: '/usr/bin/curl "http://denon/MainZone/index.put.asp?cmd0=PutMasterVolumeSet%2F{{ states.sensor.denon_volume.state|float + 5 }}"'
    set_denon_voldown_5db: '/usr/bin/curl "http://denon/MainZone/index.put.asp?cmd0=PutMasterVolumeSet%2F{{ states.sensor.denon_volume.state|float - 5 }}"'
  • Scripts to call the above volume changes:
      sequence:
        - service: shell_command.set_denon_volup_5db
      sequence:
        - service: shell_command.set_denon_voldown_5db
      sequence:
        - service: shell_command.set_denon_volup_10db
      sequence:
        - service: shell_command.set_denon_voldown_10db
So while the above mostly works, here’s my problem assuming the current volume level is -30dB, and the +10dB script is called:
  • The shell script uses the current sensor value for the volume
  • Adds +10dB
  • Sends the appropriate designated value (-20dB) to the receiver via curl
  • yay!
but if I activate any of the scripts within the next <10 seconds (prior to the scrape sensor picking up the new volume level), it just sends the previous designated volume level.
So my idea is to have another sensor (perhaps template??) that can hopefully do two things:
  1. Every time the scrape sensor grabs a new value, apply it to this new sensor
  2. Every time one of the scripts / shell commands is calculated, stick this new value into the sensor and remain until the scrape sensor goes and grabs the current value again
I’m not sure how to do it but i think this is what I need to do. Is it possible? Or am i way off?
Thanks!
You’d need an input number to store the value. You’d need an automation to to have the scrape sensor update the input number. And an automation for the input number to call a shell command based on the input number level. The value is essentially stored in the input number. Be warned tho, something like this will have a feedback loop and if your polling is set to 10 seconds, you might get wonkyness.
Your other option is to do the same thing with an mqtt sensor. Again, has the same limitations.
thanks mate.
I guess in reality - i should maybe have the script or automation grab the current volume level from the receiver instead of getting it every 10 seconds.
So when the script or automation is called:
  • grab the current value
  • add or subtract the desired level
  • send command to receiver
it might add a bit of latency but it might work much more reliably.
Why can’t you use the component again? Seems like a waste of time when you got a component. I’m guessing the reason your volume is going to 100% with it is because the volume is getting set to zero which is high in decibels. I’d just not allow that.
it doesn’t allow me to make specific jumps in volume (ie +10, -10, +5, -5) which i need to work for google assistant integration.
our previous amp had direct +10/-10/+5/-5 commands which made life real easy and we got used to it.
as for the 100% volume thing - this was prior to any automation or scripts. I’d load up the HA app on my phone and see the volume slider sitting at max volume and try to drag it down only to have the amp receive the max volume command and almost blow our ears off. The platform driver is very limited with our receiver hence the wasting of time :confused:
Yah, but you can limit the volume slider by wrapping it against a numerical slider and constrain the numerical slider to values that you want. That’s what I did, I allow mine to go between -80 and -10 db. Anytime a move over (under) -10 forces it to -10 without sending the signal to the receiver. Just hide the media control in the UI and it won’t ever be a problem.
Beauty of this setup is that it inverts the slider. So when the system starts up, it will be low worse case scenario. The input slider also store’s the volume of your slider if you remove initial -80 and use restore state.
  yamaha_receiver:
    name: Zone 1 Volume
    initial: -80
    min: -80
    max: 0
    step: 5
- alias: Zone 1 Volume (Media to Slider)
    - platform: state
      entity_id: media_player.yamaha_receiver
  condition:
    - condition: template
      value_template: >
        # convert to decibel.
        {% set converted = ( -1.0 + trigger.to_state.attributes.volume_level | float ) * 100.0 | round(0.0) %}
        # Removes feedback loop
        {{ converted != states('input_number.yamaha_receiver') | float }}
     service: input_number.set_value
     data_template:
       entity_id: input_number.yamaha_receiver
       value: >
          {{ ( ( -1.0 + trigger.to_state.attributes.volume_level | float ) * 100.0 ) | round(0.0) }}
- alias: Zone 1 Volume (Slider to Media)
    - platform: state
  condition:
      value_template: >
        # convert from decibel.
        {% set converted = (1.0 - trigger.to_state.state | float / 100.0) | round(2) %}
        {{ converted != state_attr('media_player.yamaha_receiver','volume_level') | float }}
    - service: media_player.volume_set
      data_template:
        volume_level: >
          {{ (1.0 - trigger.to_state.state | float / 100.0) | round(2) }}
In case you’re interested, I had a PR a few days ago that added template functionalities to input_number that allowed its value to be updated based on a template, and allowed for running a script (or sequence of services) when its value is changed via input_number.set_value. It didn’t get merged, but you could use or adapt the code if you’d like. I think it would enable you to accomplish this without having to define those automations.
Pull request
input_number/__init__.py
Thanks. I actually don’t use those automations anymore, moved over to appdeamon a few years ago. I just dug em up from when I used the built in automations.
thanks a bunch @petro. I’ve tried to apply your code to my config but for whatever reason, the automations aren’t being triggered on either slider change or receiver volume change:
last_triggered: null
friendly_name: Zone 1 Volume (Media to Slider)
friendly_name: Zone 1 Volume (Slider to Media)
They’re both enabled and there’s no errors in the log. Might need to enable debugging.
automation:
#### PETROS AWESOME VOLUME AUTOMATION ###
- id: denon_media_to_slider
    - platform: state
      entity_id: media_player.denon_avr_3310
  condition:
      value_template: >
        {{ converted != states('input_number.denon1_receiver') | float }}
     data_template:
       entity_id: input_number.denon1_receiver
       value: >
- id: denon_slider_to_media
    - platform: state
  condition:
      value_template: >
        {{ converted != state_attr('media_player.denon_avr_3310','volume_level') | float }}
      data_template:
        volume_level: >
this is probably the most complex code i’ve got in my config! a little over my head :grin:
Do you have the input number configured?
Also, in my case, the media player had to be on for it to work.
yeah of course:
  denon1_receiver:
    name: Zone 1 Volume
    initial: -80
    min: -80
    max: -10
    step: 5
Receiver is rarely off. The denon platform volume slider works ok but neither of the automations have triggered no matter what i change (input slider or amp vol).
I can see the input number change in the dev tools, as well as the volume.
Ok, try to remove the condition in the center of the automations.
Also, take a screenshot of the media player’s attributes when on and the input number. This was an old automation and I’m wondering if things changed.
I also have a Denon, created a script to send +3 or -3, you can choose the value …
That script I call with a template switch I use in Google assistant
If interested in the script?
Thanks @petro
Removing the conditions in both automations shows the automations being triggered in dev states panel now.
Heres what the input number and denon media player look like in the states window:
The receiver doesn’t respond to any number input from the slider unless the slider hits 0, to which the receiver is then set to 0dB (assumingly due to the conditions templates not doing the conversion to/from -dB?)
hi @pergola.fabio
Thanks for the offer - id love to see yours too. This is a great community :slight_smile:
I am using this script, but be careful with volume, I use 0.03 for instance , to increase with 3
I also have sliders in my config in Lovelace, that actually read current value , and also set the value if you’re change the slider …
This script I use for increase/decrease
I have something similar with my lights at home. I have set up telegram to work with my HA and when I send the command “brighter” (it’s a bit more complicated) it makes my lights brighter. Same for darker.
I am sure you can adapt that for your use. Especialy when you combine it with input_number, set as slider!
So what I would do is the following:
  1. (Optional)
    Create an automation that triggers when your Receiver turns on. No condition. Action is to read the current volume and set the input_number accordingly. (add a delay in case your receiver takes some time to turn on)
    This is optional since once you change your slider, it’s updated anyway - but it’s a nice way to be percise in control!
  2. Make an automation, that triggers when input_number state changes. Your input_number is the desired volume. -> when you change the input value, the automation sends the new volume to your receiver. If you want you can set a condition checking if the receiver is on.
  3. As you want -10 -5 +5 + 10 dB, you want 4 automations/scripts. Scripts are provably easier here.
    The action is a simple math operation. You grab the current input_number and add/subtract the desired value to it. Since you change the state of input_number, the second automation should trigger! (If it does not, don’t worry! Just add the set_volume action in your script too. So the script updates input_number AND media_player.volume!)
    The line for my setup is
    lights.turn_on:
    entity_id: MY_LIGHT
    data_template:
    brightness: {{ states.lights.MY_LIGHT.attributes.brightness | int + 10 }}
You need to adapt it for your setup, but that’s what should work and be easy to use.
I’m typing from my phone, so sorry for not providing more accurate info.
template_number:
  denon1_receiver:
    name: Zone 1 Volume
    initial: -80
    min: -80
    max: -10
    step: 5
    value_template: >
      {% if state_attr('media_player.denon_avr_3310', 'volume_level') %}
        {{ ( ( -1.0 + state_attr('media_player.denon_avr_3310', 'volume_level') | float ) * 100.0 ) | round(0.0) }}
      {% endif %}
    set_value_script:
      data_template:
        volume_level: "{{ (1.0 - value | float / 100.0) | round(2) }}"
Try this template_number component. Just copy the folder I linked to your custom_components folder. I think the above configuration will work, no automations needed.
It’s odd that your state is set to -65.8392874932874 or whatever when the slider is constrained to increments of 5.
Anyways, the root cause is because your equations are different than mine. I reworked them. Change your conversion lines to this:
    - platform: state
  condition:
      value_template: >
        {% set converted = ( -1.0 + trigger.to_state.attributes.volume_level | float ) * 100.0 | round(0) %}
     data_template:
       value: >
          {{ ( (-1.0 + trigger.to_state.attributes.volume_level | float ) * 100 ) | round(0) }}
    - platform: state
  condition:
      value_template: >
        {% set converted = (1.0 + trigger.to_state.state | float / 100) | round(2) %}
      data_template:
        volume_level: >
          {{ (1.0 + trigger.to_state.state | float / 100) | round(2) }}
unfortunately, still not working. as soon as the conditions are in place, the automations never get triggered
