Is the customize.yaml file still needed (with lovelace frontend)?
Hi all,
I’m chasing up why I get a fail from the Check HomeAssistant Configuration add-on regarding the customize.yaml file entities when I test against 0.94.0.
Without going into details yet, I’m wondering if the customize.yaml file and the include in configuration.yaml is obsolete now, and I missed that in the release notes ?
No. It’s actually used by the entity customization in the frontend.
You could post your issue and others can help
OK, tomorrow :slight_smile:
Nothing to do with your customize yaml. :wink:
What do you make of the - customize: [source /tmp/config/configuration.yaml:12] ?
That line is messed up because of the previous one. Fix your external directories first. Then check again.
