Is the 'homeassistant' global variable a default for the add-on?
I’ve added so many global variables that I’ve forgotten if the ‘homeassistant’ global variable in NodeRED, which contains all of the states and services in HA, is loaded by default into the global variables or if I created this somewhere with a “global.set” and have forgotten about it.
Thanks!
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/node/config-server.html#enable-global-context-store
I thought so…thanks.
