Is the JSON parsing in rest sensor working well?
Hello, I have some strange behavior. I have server providing this JSON response:
{“btc”: {“luck_b10”: “0.80”, “luck_b50”: “1.11”, “luck_b250”: “1.01”, “hash_rate_unit”: “Gh/s”, “pool_scoring_hash_rate”: 7970543307.1116, “pool_active_workers”: 151559, “round_probability”: “0.08”, “round_started”: 1636128319, “round_duration”: 941, “pps_rate”: null, “blocks”: {“708346”: {“date_found”: 1636128319, “mining_duration”: 31730, “total_shares”: 58755565025679, etc. etc.
I need to get value “mining_duration”. for that, I would use following statements, that are working well:
sensor 49:
  - platform: rest
    resource: https://slushpool.com/stats/json/btc/
    method: GET
    headers:
      SlushPool-Auth-Token: my token
    value_template: "{{ value_json.mining_duration }}"
    json_attributes_path: $.btc.blocks.708346
    json_attributes:
      - "mining_duration"
    scan_interval: 37
the problem is that the block number in first line of array “blocks” is not constrant and it changes. So according to the JSON documentation, I would replace
with first record on the “blocks” array
json_attributes_path: $.btc.blocks[0]
but that is not working and no value is returned. That leads me to suspicion that implementation of JSON parser is not standard.
Any advice? Thank you!
It won’t work. The “blocks” from your json is a dictionary, not a list.
You have to know the block number, or store the full block in an attribute, and use a template sensor to iterate it to find the one you’re interested in.
EDIT: Just do the iteration in “value_template”
I solved it by statement:
json_attributes_path: $.btc.blocks.*
