Hi everybody,
I am looking for a very specific type of hardware that ideally works with Home Assistant (ESPHome, zigbee2mqtt; ideally not z-wave).
Let me explain the situation:
I have a gated driveway that connects to a public road. The gate is solid, so no see-through. Also, sometimes I need to assists somebody at unpredictable times (sometimes not for a week, sometimes twice a day). This needs to happen relatively quickly, so when I need to drive, I need to open the gate, get in my car, and drive.
Here in Germany, you are not allowed to point your security cameras at public ground (as far as I know). There is a shop on the opposite site of the road (opposite from my gate). While it is illegal to block driveways, people park there on a regular base to go to this shop. It is always different people.
A âplease donât block the drivewayâ sign doesnât help. While I try and talk to people when they park there (some understand, some be like âIâll just be 5 minutes, donât be so uptight!â), since it is always different people, this doesnât help. Those that understand (hopefully) wonât park there again, others donât care - but most are just random people who park there once. Once for them, multiple times a day, is countless times for me.
So I cannot monitor this space via camera because it would be illegal. I donât have reason to surveil this area, so I must not. I doubt whoever is in charge of this will care that I might sometimes be in a hurry to get out of my driveway, so I do not want to risk getting in trouble for using a camera there.
The reason I want to do this is that I could have Home Assistant alert me as soon as a car parks there (for x seconds/minutes), then I could go outside and ask whoever parked there to use on of the many - usually unoccupied - parking spaces right around the area. Itâs not like they even have to block my gate, the shop most people go to has multiple spots for customers.
So this way, Iâd always have a heads up that I might not be able to leave through my driveway before Iâd actually have to, and could act accordingly.
Finally, my question
Is there a âplug and playâ kind of device I could purchase and mount to my gate in order to know whether or not somebody is blocking my gate?
I have thought of:
Downside: Iâd have to build this myself. While I already use the Ultrasonic Sensor to measure the level of my rainwater tanks (so I know how it works), I wouldnât know how to securely mount and power this. Couldnât be on the outside of my gate, because it could just be ripped off / unplugged (and yes! People get very touchy when you ask them not to inconvenience you by not breaking the law, so I could imagine somebody doing this!!).
Thoughts: I donât have experience with this. Could I mount it on the inside (facing my property) side of my (metal) gate and still detect whatâs going on on the other side (facing the public road, or rather, the direct outside of my gate)? And would I be able to âmissuseâ it to actually measure occupancy - not just motion?
Likely downside: Iâd need at the very least two of these to determine whether somebody actually parks there. Likely itâd even have to be four at least, two per each side of the gate to avoid false positives.
What do you suggest? Unfortunately, there doesnât seem to be a âsensibleâ solution⌠I mean, people simply respecting the area as a non-parking area, or at least talking sense into them (not possible because it is not just one or two people doing this). I need some kind of technical solution so I can at least be on alert that the driveway might be blocked once again before I actually might need to leave in a hurry.
I could just block the driveway myself, meaning that Iâd park my car outside, in front of the gate. I have done this before. Since itâs the way to my property, nobody will get me in trouble if I do this. However, Iâd prefer to park on my property instead of on the road - so this is a workaround Iâd like to avoid.
Any technical solution you can recommend? Thank you in advance for your ideas
