Can’t advise on that, I use the HA native Zwave JS. Not familiar with UI.
But familiar with Fibaro Eyes for a long time…
If the Z-Wave network is getting spammed, no amount of processing power on the HA side will fix this. I once had a power plug malfunction in a similar way, in this case unplugging it and replugging was enough to fix. So if this a battery powered device, I’d first try removing the batteries for a minute or two.
Exactly, why I said very clear, that changing the system machine does not necessary fix this problem already before this spamming came to the table
I would not change anything in the associations nothing there looks out of order (except tour controller not being node 1, but that could be from a controller shift sometime in the past) but it doesn’t matter, because…
I would do exactly as @BebeMischa suggested and exclude/rejoin that misbehaving node. Then see how your network is doing.
I presume that this is the same activity as Exclude/Include in terms of resetting the security as mentioned by you?
It is not. You have to completely disjoin / rejoin a device to change its security level.
It could come across as being similar. Ok, thanks for the feedback!
