I’m running HA on as rpi4B 4GB for 2 months now (switched from zwave.me) with some integrations and Zwave with zway UZB gen5 controller stick
I have around 120 zwave nodes, almost all of them zwave+
Alls is kind of ok, if I look at cpu/mem load of the Rpi then I don’t see any high values, temperature also ok.
But, now here’s the thing, from time to time, on very simple automations , it takes like 8 seconds before a light turns on. for example, I have a fibaro multisensor and fibaro dimmer2 switch close to the controller, I created an automation to turn the light on when motion is dected however, I can see an 8 seconds delay between the motion detection and the “turn on” of the light.
I can’t figure out why, is it zwave, is it HA, is it the hardware…
So, my question, if you like at my zwave network (amount of nodes) , is the RPI the right solution ? is the delay all “in the network” or can cpu power , hardware latency (internal) also be a factor here ? would switching to an intel NUC for example solve this ? (tough question, I know)
Like to hear your experiences, especially from the ones with over 100 zwave nodes as well.
