Is there a arduino #define alternative?
I was wondering if there is an option for defining all the pins in one place and only using pin-aliases for the components later?
The functionality I’m searching:
When programming an Arduino you can write #define LCD_CS 27 and then you can use LCD_CS instead of writing 27.
Is there a way to do something like it in esphome? so fare I could not find anything.
thx for the answer but this does only work for strings :confused:
GPIO27 is a string.
