so i cant manually delete more then 1000 fresh tokens
is there a database i can just delete? is there an app the does it?
as i run multiple instances of my home assistant on my computer so they always running… and i usually click the button keep me loged in always… but its getting out of hand… all these tokens
i was wondering if there is a fix yet to mass delete tokens? i think maybe up to 2500 tokens going back a couple years now… id like to mass delete it… does the latest version of home assistant have something? or a database i can simply just delete?
im guessing to only get rid of the tokens normally is to log out each session… but who does that i just load it and click X on the browswer to close it… but it is always creating a new token… if i go from computer or cell phone… and then re creates a new one just adds up
i just wanna mass delete them all… even when i changed IP address it still has the old ip address as a token. from a year ago… i just wanna mass delete… a Delete All
cuz i never click logout… i just close it and reload it when i need it etc… maybe a feature when you close browser… it logouts the refresh token
and if you go back and forth from IP to home assistant name
so
192.168.0.2 = homeassistant
thats 2 tokens
192.168.0.2 is a token
homeassistant is another token
yet are the same address so your computer would have 2 tokens for homeassistant…
so i was hoping a mass delete or an expring date of like 5 days maybe
also if you change your IP on your computer… and use home assistant… well you just created a new token… also if you clear your browser cache… and you relogin to home assistant… well you created a new token so it adds up
