WoJWoJ
January 9, 2022, 8:24am
1
I have a wall switch that can send several messages (single press, double press, long press, …).
I would like to bind to each of these messages specific actions.
Is there a way to keep them all in one automation, where I would have a decision tree (or a multi condition similar to the “switch” command in JavaScript or Go), or do I have to make a separate automation for each message?
(I am using pyscript for that, but was curious if there was a built in solution, I could not find anything along these lines)
As per what @francisp has linked to, here is my example using the single, double and long presses of a Xiaomi button.
automation:
- alias: 'Ensuite Remote Button'
- platform: event
event_type: xiaomi_aqara.click
event_data:
entity_id: binary_sensor.switch_158d00016bf679
click_type: single
- platform: event
event_data:
click_type: double
- platform: event
event_data:
click_type: long_click_press
choose:
- conditions:
- condition: template
value_template: "{{ trigger.event.data.click_type == 'single' }}"
sequence:
- service: automation.turn_off
entity_id: automation.ensuite_lights_auto
- service: switch.turn_off
entity_id: switch.adaptive_lighting_ensuite
- service: light.turn_on
entity_id: light.ensuite_downlight
white: 255
entity_id: light.ensuite_led_strip
effect: solid
rgbw_color: [0,0,0,255]
- conditions:
value_template: "{{ trigger.event.data.click_type == 'double' }}"
sequence:
- service: light.turn_off
entity_id: light.ensuite_lights
- conditions:
value_template: "{{ trigger.event.data.click_type == 'long_click_press' }}"
sequence:
- service: automation.turn_on
- service: switch.turn_on
data_template:
brightness_pct: "{{ state_attr('switch.adaptive_lighting_ensuite', 'brightness_pct') | int }}"
rgb_color: "{{ state_attr('switch.adaptive_lighting_ensuite', 'rgb_color') }}"
white_value: 0
That automation can actually be simplified even more using Trigger ID’s but I just haven’t updated it yet.
