I’ve explored various cookbooks and blog posts, and I have lighting automation flows in various different formats.
Switch with Timer
In this example:
- Motion is detected for more than 5 seconds
- Between a time range (that Time Range Switch is very useful)
- A Switch sets a payload of either On or Off
- On is sent to a State node which is checked
- The appropriate lights are turned on
- A 5 minute timer is also started
- After 5 minutes of no motion, the lights are turned off
Switch with Timer example
"id": "afe16b4b6239b5ff",
"type": "server-state-changed",
"z": "d3a07d369eada1b3",
"name": "Kitchen Motion",
"server": "c195525b96cc1e8a",
"version": 4,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.kitchen_motion_motion",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "str",
"haltifstate": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": true,
"for": "5",
"forType": "num",
"forUnits": "seconds",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 100,
"y": 80,
"wires": [
"a09192b2f6cbbe67"
"id": "a09192b2f6cbbe67",
"type": "time-range-switch",
"name": "Sunset Start and Sunrise End",
"lat": "53.5695493",
"lon": "-113.4513922",
"startTime": "sunsetStart",
"endTime": "sunriseEnd",
"startOffset": 0,
"endOffset": 0,
"x": 270,
"y": 140,
"wires": [
"df56e5ea0a2306ba"
"id": "0f8033e8f5fc3442",
"type": "stoptimer",
"duration": "5",
"units": "Minute",
"payloadtype": "num",
"payloadval": "0",
"name": "",
"x": 600,
"y": 140,
"wires": [
"4ea24d15f83eeb8f"
"id": "df56e5ea0a2306ba",
"type": "switch",
"name": "",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 350,
"y": 80,
"wires": [
"0f8033e8f5fc3442",
"647e7d5848a1c87d"
"0f8033e8f5fc3442"
"id": "647e7d5848a1c87d",
"type": "api-current-state",
"name": "Kitchen Group On",
"version": 3,
"outputs": 2,
"halt_if": "on",
"entity_id": "switch.kitchen_group",
"blockInputOverrides": false,
"value": "",
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 610,
"y": 80,
"wires": [
"1699b4d474b9253b"
"id": "1699b4d474b9253b",
"type": "api-call-service",
"version": 5,
"debugenabled": false,
"domain": "switch",
"service": "turn_on",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 850,
"y": 80,
"wires": [
"id": "4ea24d15f83eeb8f",
"name": "Kitchen Group Off",
"version": 5,
"domain": "switch",
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"mergeContext": "",
"queue": "none",
"x": 850,
"y": 140,
"wires": [
"id": "96d627ce2bbf2f4c",
"type": "comment",
"name": "Kitchen Motion detected for 5 seconds between sunset start and sunrise end",
"info": "",
"x": 290,
"y": 40,
"wires": []
"id": "f85286f19134a142",
"type": "comment",
"name": "Switch Kitchen Group on for 5 minutes, switch Kitchen Group off after 5 minutes of no motion",
"info": "",
"x": 900,
"y": 40,
"wires": []
"id": "c195525b96cc1e8a",
"type": "server",
"name": "homeassistant.instantdreams.org",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": ": ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "default",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": false
Switch with Wait Until
In this example:
- The light is switched on
- A wait until entity is also called
- After 2 minutes of no motion, the light is turned off
Switch with Wait Until example
"id": "9e2a08f5.4634b8",
"name": "Hall Motion",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.hall_motion_motion",
"outputs": 2,
"for": "5",
"forType": "num",
"value": "",
"property": "data",
"value": "",
"value": "",
"x": 120,
"y": 260,
"wires": [
"b47ee5de757edd5b"
"id": "6a54b527.806bec",
"name": "Hall Light On",
"version": 5,
"domain": "light",
"areaId": [],
"deviceId": [],
"entityId": [
"light.hall_ceiling"
"data": "{\"brightness_pct\":1}",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"output_location": "",
"output_location_type": "none",
"x": 830,
"y": 260,
"wires": [
"id": "c066de8f.8a0e2",
"type": "ha-wait-until",
"name": "",
"version": 2,
"outputs": 2,
"entityId": "binary_sensor.kitchen_motion_motion",
"entityIdFilterType": "exact",
"property": "state",
"comparator": "is",
"value": "on",
"valueType": "str",
"timeout": "2",
"timeoutType": "num",
"timeoutUnits": "minutes",
"checkCurrentState": true,
"blockInputOverrides": true,
"x": 580,
"y": 320,
"wires": [
"28f00104.71e9de"
"id": "28f00104.71e9de",
"name": "Hall Light Off",
"version": 5,
"domain": "light",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 830,
"y": 320,
"wires": [
"id": "b47ee5de757edd5b",
"name": "Sunset Start and 22:30",
"endTime": "22:30",
"startOffset": 0,
"endOffset": 0,
"x": 250,
"y": 320,
"wires": [
"b2adbd1cb06dd9d0"
"id": "b2adbd1cb06dd9d0",
"type": "switch",
"name": "",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 350,
"y": 260,
"wires": [
"6a54b527.806bec",
"c066de8f.8a0e2"
"c066de8f.8a0e2"
"id": "a50ac45220029805",
"type": "comment",
"name": "Hall Motion detected for 5 seconds between dusk and dawn",
"info": "",
"x": 230,
"y": 220,
"wires": []
"id": "efa5251255230901",
"type": "comment",
"name": "Switch Hall Ceiling on for 2 minutes, switch Hall Ceiling off after 2 minutes of no motion",
"info": "",
"x": 820,
"y": 220,
"wires": []
"type": "server",
"version": 5,
"addon": false,
"cacheJson": true,
"heartbeat": false,
Trigger
In this example:
- A Trigger sends a payload of “turn_on” plus additional information to a light entity or group
- The Trigger then waits for a set number of minutes, extending the delay if additional messages arrive
- After the delay the Trigger sends “turn_off” to the light entity or group
Trigger example
"id": "41396f468be568a3",
"name": "Front Motion",
"version": 4,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "binary_sensor.front_motion_motion",
"outputs": 2,
"for": "5",
"forType": "num",
"value": "",
"value": "",
"x": 110,
"y": 1000,
"wires": [
"ef9d53cccca844c0"
"id": "ef9d53cccca844c0",
"name": "Golden Hour Start and Golden Hour End",
"startTime": "goldenHour",
"endTime": "goldenHourEnd",
"startOffset": 0,
"endOffset": 0,
"x": 280,
"y": 1060,
"wires": [
"24f88e58e8e31bcd"
"id": "24f88e58e8e31bcd",
"type": "trigger",
"name": "",
"op1": "{\"service\":\"turn_on\",\"data\":{\"transition\":4,\"brightness_pct\":60}}",
"op2": "{\"service\":\"turn_off\",\"data\":{}}",
"op1type": "json",
"op2type": "json",
"duration": "1",
"extend": true,
"overrideDelay": false,
"units": "min",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 450,
"y": 1000,
"wires": [
"e3fcc03bafc96ae2"
"id": "e3fcc03bafc96ae2",
"name": "Front Ceiling",
"version": 5,
"domain": "light",
"service": "{{payload.service}}",
"areaId": [],
"deviceId": [],
"entityId": [
"light.front_ceiling"
"data": "",
"mergeContext": "",
"queue": "none",
"x": 650,
"y": 1000,
"wires": [
"id": "d10ea8be3530a253",
"type": "comment",
"name": "Front Motion detected for 5 seconds between Golden Hour Start and Golden Hour End",
"info": "",
"x": 320,
"y": 960,
"wires": []
"type": "server",
"version": 5,
"addon": false,
"cacheJson": true,
"heartbeat": false,
Summary
Which of these is generally considered the best way to manage lighting automation? I think the use of Trigger feels like the cleanest, but I’m not sure if it’s the best.
