Is there a more elegant way to format this?
As a relative newbie and non-programmer I hammered out this value_template for a binary_sensor. It works well but looks like a big run-on sentence. Is there a way to format it in an easier to read indented stack? Thanks.
  sensors:
    day_night:
      value_template: "{{ ((state_attr('sun.sun', 'elevation') | float > 0) and (state_attr('sun.sun', 'rising') == true)) or ((state_attr('sun.sun', 'elevation') | float > -5) and (state_attr('sun.sun', 'rising') == false)) }}"
PS, the intent is to turn on a helper at 0° sun angle in the morning and turn it off at -5° at night.
  sensors:
    day_night:
      value_template: >-
Would something like this make it more readable for you?
I prefer to set variables if I’m using something multiple times:
{% set rising = is_state_attr('sun.sun', 'rising', 'true') %}
{% set elevation = state_attr('sun.sun', 'elevation') | float(0) %}
{{ (elevation >= 0 and rising) or (elevation > -5 and not rising) }}
So to do it this way, is this how I would need to format it?
  sensors:
    day_night:
You should be using the current template format instead of the legacy format.
template:
  - binary_sensor:
      - name: "Day Night"
        state: >
        availability:  "{{ state_attr('sun.sun', 'elevation') | is_number }}"
This will create a sensor binary_sensor.day_night which will have the state on during your defined day time and off at night.
