Rainer70
(Rainer)
1
I’d like to implement a simple integration.
(1) Config host + credentials
(2) Periodically poll a rest endpoint in the internet
(3) Expose results of the poll as sensor values
Should be pretty simple… is there kind of example for that common task?
koying
(Chris B)
2
You mean a custom integration? That wouldn’t be a “common task”
What would it do the that the builtin Restful one wouldn’t?
Rainer70
(Rainer)
3
Maybe I don’t understand the docs of Restful. I have an endpoint that delivers something like:
[ {'name': 'a', 'max': 100, 'actual': 10, 'active': true},
{'name': 'd', 'max': 50, 'actual': 40, 'active': true},
{'name': 'q', 'max': 1000, 'actual': 180, 'active': false}
And I want to make sensors out of a, d, q but this is not a fixed set of objects. Think that won’t work with the RESTful plugin.
