Preface this with US standard, decora style, and retrofit into an existing switch boxes.
The problem I have found is that all of them are complex, exposing stuff (sliders, extra buttons, weird buttons) that guests and the un-enlightened (non-hard core HA types) get frustrated using.
The simplest ones that are a single direction momentary are just as annoying as I see people tap the top and nothing happens (it doesn’t rock that direction).
I want just a dual direction, return to center momentary plate. Tap top, turns on. Tap bottom turns off. Hold up increase brightness. Hold bottom, decrease brightness.
I found one solution, using a Leviton PRO momentary switch which has the return to center and up and down momentary. But the thing is so deep it leaves no room behind it for a smart dimmer module (like a Shelly) to do the actual work. I have yet to find another switch like it.
Any suggestions on a smart switch I may have overlooked? A dual direction momentary dumb switch that isn’t as deep as full smart switch?
First, you didn’t say what communications technology you prefer: Zwave, zigbee, Wifi, etc?
Second, this is easy. If you are ok using Zwave, many of the Zooz dimmers do exactly what you describe: Decora style, low-depth, momentary tap the top paddle for on, hold for level adjust, etc. You have the ability to program the dimmer to act exactly how you want it. For example, if you don’t care about scene control then you can turn that feature off and it will be a simple dimmer.
Decora paddles, fit fine in a retrofit box. The only other button is a tiny, tiny config button that I basically never touch on purpose or by accident. Zwave, Zigbee, or Matter. They have standard dimmers, ceiling fan controller, and even ones for switched outlets. They all look 99.5% the same.
Finding a shallow dumb momentary switch is tough. The Zooz Z-Wave dimmers are low-depth, Decora style, and you can program them to do exactly what you want, tap top for on, hold for dimming. Might be worth ditching the Shelly for one of those.
A US-style momentary Decora switch with a center-return rocker might be the best fit. Look for a dual-action momentary switch with separate up/down contacts. Pair it with a Shelly dimmer module behind the switch. Check box depth and wiring clearance before choosing hardware.
I’ve removed most of my hidden devices like Shelly and Sonoff and replaced with Inovelli (blue series) switches and dimmers. Because of my advanced age I didn’t want to leave an easter egg hunt for some future homeowner to deal with.
Also, I don’t know about Jasco Z-wave products but if you choose to go with Zigbee please do not buy Jasco (GE enbrighten), you have been warned. Zigbee2MQTT
That has been the problem, the dual action momentary are RARE! I have only found the one from Leviton and its a pretty thick boy! It is my preferred solution, but just not finding the switch that allows room behind it for a smart controller.
Thanks for info. This is the closest match for look and feal. My system doesn’t currently support ZWave, but I am not afraid to add the support as HA makes it flexible and easy enough. Already have WiFi, Matter, Thread, RF433, what’s another supported protocol
Correct. I have seen Zooz Inovelli GE Wemo Eaton all have this air gap feature - a little tab you pull and then push back to reset the switch… save a trip going to your breaker panel.
Update:
I purchased several Zooz 800 Series, mix of dimmer and just on/off and installed them. Test in one location ongoing, installed/replaced inside a metal wall outlet (industrial construction in the building with metal studs in some walls).
I added a Home Assistant Connect ZWA-2 to add Z-Wave to my HA system.
So far, they are working well. The metal boxes and wall studs don’t seem to degrade connectivity even with the ZWA-2 two walls away (but only about 15 feet / 4 meters).
The onboarding process was easier than Matter/Thread was, and no disconnects yet like I have had with Matter/Thread. Time will tell.
The Zooz do seem well made, and thin enough to make installation and folding the wires NOT a pain. The simplicity of the switches in day to day use is appreciated.
While the Shelly ones have a fancy touch surface to slide your finger on to dim and bighting, just trying to turn on or off you often change the dim level by mistake. Almost every time they get used, they inadvertently get changed.
