Is there a solution to the Tuya component problem with Home Assistant?
Hi, I had problems with tuya component. when adding devices they do not turn on and the button is returned. In an article i discovered that there was already a solution.
They say it is because of the api update. I am trying to download the github file but my computer warns me “The website you are going to access contains harmful programs” and I cannot download the file does anyone know if what is found on this page is true ?
What other method is there to solve this?
Did you look into this? https://github.com/ct-Open-Source/tuya-convert
Yes as @Bartem suggested - convert them to either Tasmota or ESPhome according to your preference. I just did this to all my Tuya bulbs as they became slow to respond and unreliable, with excellent results.
