Is there a technical reason why MEROSS equipment is not supported?
I am new to ESPHome but after a few tests I moved all my Sonoff devices on that solution - it is fantastic.
I have some MEROSS equipment (https://www.meross.com/) but none of it is supported by ESPHome. I have zero knowledge about electronics so I apologize if my question does not make sense.
  • is this because it runs on something different form ESP8266/ESP32
  • or is this because there is no interest in these products?
  • or because it is not possible to flash it?
  • or something else?
I don’t have any meross equipment, but
that would be my first thought.
If it has an ESP, it can be flashed and can run esphome.
I just discovered via http://projects.nesrada.de/mss310/index.html that it is likely there is no ESP8266 module :frowning:
A little search and it looks like at least one of their device is ESP based :wink: https://templates.blakadder.com/meross_MSS425.html
Meross support within HA is via HACS.
Yes, but this is via the MEROSS cloud and not a direct integration of the device.
Though I must say that it is very reactive and I do not see any special lags.
