I did already looked into the Home Assistant documentation around navigate. It seems it could only navigate to another dash (or I’m not seeing any functionality to open a card).
@CO_4X4 Can you point me to a card-mod and example code that would allow me to do this? I’m still just getting started with Home Assistant.
Look at the documentation regarding the Pop-Up card. Basically it replaces the more-info of a button so that when you view more-info (either your long press or if you configure your tap action to be more-info) then it pops the pop-up instead and the pop-up is just another dash-in-dash essentially.
Navigation lets you navigate between panels in a dashboard. You can navigate between dashboards, for example if you don’t want them to show in the sidebar.
