I have a bunch of windows (sensors) and covers that I would like to pair so I can use this information to make some automations. My automations are done in NodeRED, so I can get a list of all opened windows after a weather state change or the sun dawn. I would like, for example, that if one window is open and it starts raining close the corresponding cover. Sure I can do is match one by one bay hand, but what I would like is been able to link, associate or pair the information in the entity so when I recover the information from any windows I have a property that says which is its cover.
The question is: Is there a way of adding a custom property to an entity?
Thanks,
This is best done using a structured naming schema.
If you have a window sensor called:
binary_sensor.south_window
And a shutter or blind called
cover.south_window_shutter
Similarly for north, west, and east windows, then you can do things like:
platform: state
entity_id:
- binary_sensor.south_window
- binary_sensor.north_window
- binary_sensor.east_window
- binary_sensor.west_window
to: 'off'
service: cover.close_cover
entity_id: "cover.{{ trigger.object_id }}_shutter"
Using this, if any window is closed then the corresponding shutter/blind will also close.
Entity ids are composed of a domain and an object_id:
domain.object_id
so if the entity_ids for your binary_sensors and covers (domains) have similar object_ids you can easily associate them.
While I tend to use the method Tom suggested, you can also assign custom attributes to the individual entities:
homeassistant:
customize:
binary_sensor.south_window:
cover: "cover.southern_blinds"
binary_sensor.north_window:
cover: "cover.north_shades"
binary_sensor.east_window:
cover: "cover.master_roller_blinds"
binary_sensor.west_window:
cover: "cover.kitchen_shutters"
cover.southern_blinds:
window: "binary_sensor.south_window"
cover.north_shades:
window: "binary_sensor.north_window"
cover.master_roller_blinds:
window: "binary_sensor.east_window"
cover.kitchen_shutters:
window: "binary_sensor.west_window"
Entity-based attribute automation example
platform: state
entity_id:
to: 'off'
entity_id: '{{ trigger.to_state.attributes.cover }}'
OR to each window/cover pair… something like window_id
Window ID config example
homeassistant:
customize:
window_id: "S1"
window_id: "S1"
window_id: "N1"
cover.north_shades:
window_id: "N1"
window_id: "MB1"
window_id: "MB1"
window_id: "K2"
window_id: "K2"
Window ID automation example
platform: state
entity_id:
to: 'off'
entity_id: >
{{ states.cover
| selectattr('attributes.window_id', 'defined')
| selectattr('attributes.window_id', 'eq', trigger.to_state.attributes.window_id)
| map(attribute = 'entity_id') | list }}
Thank you for your answers. Both works perfectly. For me the solution that best fits is the “custom attributes” as i tend to keep the original ids for every device, I got some mess up at the beginning replacing ids so I decided not to do so.
I didn’t know that you could create your own custom attributes, I thought that it what for customising the existing ones.
