When defining template sensors, I’d like to add a description as a reminder how it works or where it gets its data from. Is this possible?
Something like this:
sensors:
veryspecialsensor:
value_template: "if this then that else something else"
friendly_name: "some friendly name"
description: "This is a very sophisticated sensor, taking its data from this and that and so on"
You can use a YAML comment but it won’t appear anywhere in the UI.
sensors:
# This sensor is for ...
veryspecialsensor:
If you want the description to appear as an attribute of the Template Sensor, use Manual Customization to create a custom attribute called description.
Example (in configuration.yaml)
homeassistant:
customize:
sensor.veryspecialsensor:
